tool storage
发表于 2021-8-31 23:31:27 | 显示全部楼层 |阅读模式
long time lurker figured it was time to share some of my ideals. Attached ImagesI can destroy a steel ball in a rubber room
Reply:I like it all! is that an old factory cart holding the tools?
Reply:its an old flatbed bread cart from a bakery.I can destroy a steel ball in a rubber room
Reply:It's probably obvious, but why the angle on the front of the welding table? easier to clamp pipe?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Ever pull apart a transmission?Syncrowave 350Coolmate 3Millermatic 251Spoolmatic 30A
Reply:Originally Posted by ThorsHammerIt's probably obvious, but why the angle on the front of the welding table? easier to clamp pipe?
Reply:Originally Posted by Redneck Welderlong time lurker figured it was time to share some of my ideals.
Reply:Originally Posted by Redneck Weldermakes it easy to weld two joints of short pipe together.  I use alot of scrap in most of my projects. both of the carts were built from scrap i had lying around. only out of pocket cost was paint.
GMT+8, 2025-12-26 14:25 , Processed in 0.200214 second(s), 18 queries .
