cutting a barrel
发表于 2021-8-31 23:31:26 | 显示全部楼层 |阅读模式
I am trying to cut a barrel, but not quite in half. I guess you could say I want to cut about a third.  I am having a hard time getting the top and bottom measurements equal to get a straight cut. Is there a secret I do not know about? Any help is appreciated.
Reply:you can use adding machine tape as a wrap then mark with a sharpieor soap-stone (like a pipe wrap)idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctoryou can use adding machine tape as a wrap then mark with a sharpieor soap-stone (like a pipe wrap)
Reply:I mean lengthwise, sorry for the lack of explanation.
Reply:Lat it on the floor or table & measure up, then use a level to get a straight line.  Use a grinder & cutting sisc for the cuts
Reply:measure top of the  -- O--  make a  +   then do the same on the other end will give you center the end of the round ,measure up to give your one third  use a chaulk line to mark along the front ,, do the same on the back side using a level and a plumb bob will helpidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Awesome, thanks a lot. I guess my common sense is somewhere else this morning.
Reply:i bet it has to do with the date  !!!  (((  11-11-11  )))idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:or that we're just coming off a full moon.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:i used to have a neat little tool called a pipe wrap? - lost it a long time ago. it was 4" thick and about 10' long so you could wrap it over itself at least once to get a straight cut. worked great and only cost about $20 got it at my LWS
Reply:we done said that  (pipe wrap )for the one time user ,,,,adding machine tape can be usedhe is wanting to cut it long ways --not around for a grill/BBQ/smokerLast edited by prop-doctor; 11-11-2011 at 02:17 PM.idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:I ended up laying it on my bench and measuring up with a speed square, it just so happens that the top of my square was exact with where I wanted to cut.
Reply:Originally Posted by werfelmanI ended up laying it on my bench and measuring up with a speed square, it just so happens that the top of my square was exact with where I wanted to cut.
Reply:if you make a mark on the barrel as a starting point, then figure the distance from the center to the edge. take that and it will divide it into 6th by marking it all the way around it. just use every other one.
GMT+8, 2025-12-26 14:01 , Processed in 0.070248 second(s), 18 queries .
