Well I started this skid today. I will hold an SA-200, 3 bottles, and some tools. Plain and simple. I started it at the shop this morning and then brought all the stuff home to build in the driveway. Mainly to piss of the D!ck neighbor that runs his leaf blower EVERYDAY! And I get tired of being at the shop all the time. Its nice to get outside and work some!I will post more pictures when its done. Attached ImagesLast edited by jreynoldswelding; 11-18-2010 at 06:25 PM.
Reply:This was as far as I got before the neighbors I like started coming home. Just some rusty old "scrap" iron. Attached Images
Reply:Looks good, why did you weld that corner vertical instead of rolling the fram to a flat position? Not being a smart ZZZ but just curious?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:Originally Posted by kolotLooks good, why did you weld that corner vertical instead of rolling the fram to a flat position? Not being a smart ZZZ but just curious?
Reply:Originally Posted by jreynoldsweldingI will hold an SA-200, 3 bottles, and some tools.
Reply:Looks like a great start I have been toying with that same Idea my self but decided to go with another small trailer, toolbox, and tankmounts. defiently post some more pics upon completion.Vantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:Originally Posted by Brink, M.E.You sir, should enter a strong-man competition! But seriously, looking great! I hear ya on the not wanting to move stuff more than ya have to thing.
Reply:Originally Posted by GmmandanLooks like a great start I have been toying with that same Idea my self but decided to go with another small trailer, toolbox, and tankmounts. defiently post some more pics upon completion.
Reply:Originally Posted by weldbeadi would suggest that he welded it vertical because he can ...
Reply:Todays Progress, I will post some more when it is all "dressed" up with welder/bottles/goodies. 2nd coat of paint in the morning. Attached ImagesLast edited by jreynoldswelding; 11-19-2010 at 05:26 PM.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Nice welding cage. I've just one question. When putting it together did you think about letting the four vertical angle irons stick up higher and then notch the horizontal pieces in lets say 6inch below the top of the vertical piece. At which point you could burn the holes in the vertical angle for your lifting points.Harold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Looks good, JR!!! That should work very well for ya. Nice lookin' welds, as for the verticals if you can do it, why not? MikeOl' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:That looks really nice. Good looking welds too. I will ASSUME that you are using E7018...correct? I wished I could get my slag to roll off like that.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:Originally Posted by haroldmulderNice welding cage. I've just one question. When putting it together did you think about letting the four vertical angle irons stick up higher and then notch the horizontal pieces in lets say 6inch below the top of the vertical piece. At which point you could burn the holes in the vertical angle for your lifting points.
Reply:Originally Posted by mla2ofusLooks good, JR!!! That should work very well for ya. Nice lookin' welds, as for the verticals if you can do it, why not? Mike
Reply:Originally Posted by goinssrThat looks really nice. Good looking welds too. I will ASSUME that you are using E7018...correct? I wished I could get my slag to roll off like that.
Reply:Originally Posted by jreynoldsweldingThanks. Oh yea, SORRY! Forgot that part Washington Alloy, 1/8 7018 @130ish amps. The slag just peels. Pratice pratice pratice is the only advice I can give ya.
Reply:I love it when 7018 slag lifts off like that. I love trying to see if I can get the entire amount of slag to come off in one piece on my coupons. kind of a bad habit methinks but hey, it's fun!
Reply:If you set a trap you might be able to catch those beavers.
Reply:Originally Posted by riceburnerIf you set a trap you might be able to catch those beavers.
Reply:Finished! i have a couple gang boxes to put on the trailer. They will hold leads, cords, etc. Attached ImagesYou have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Very nice. I'm actually in the process of (re-)building one myself. How easy or hard is it to get those bottles out?One thing you might consider doing with those lifting eyes is either rounding them up a bit or 45-ing the top corners as well as rotating them 90 degrees so that they run lengthwise with the machine.Last edited by mb_welder; 11-21-2010 at 06:12 PM.
Reply:Originally Posted by mb_welderVery nice. I'm actually in the process of (re-)building one myself. How easy or hard is it to get those bottles out?One thing you might consider doing with those lifting eyes is either rounding them up a bit or 45-ing the top corners as well as rotating them 90 degrees so that they run lengthwise with the machine.
Reply:You know, I completely overlooked how the eyes were made out of angle iron. The upper legs will probably bend inwards with time, but it won't effect the performance. From a glance, it looked like flatbar. I would still 45 the outer corners though!Looks good, nice job.May I suggest one more set of fork pockets?With pockets on the ends it could be stabbed from the end for loading on a truck bed that has sides and also lengthwise it would make less of a blind spot and thus a narrower "ram" for the forklift operator.Good LuckLast edited by denrep; 11-22-2010 at 11:30 AM.
Reply:Nice job, looks good!Nice touch highlighting the forklift pockets."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Very nice jreynoldswelding. I like the stops on the floor plate for the cylinders to keep them from sliding. That is one thing I forgot to put on my cylinder tote. And I like how heavy duty it is.Is the round pipe what you had on hand or was that so it will "drag" nice over gravel if you have to move it a little?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manVery nice jreynoldswelding. I like the stops on the floor plate for the cylinders to keep them from sliding. That is one thing I forgot to put on my cylinder tote. And I like how heavy duty it is.Is the round pipe what you had on hand or was that so it will "drag" nice over gravel if you have to move it a little?
Reply:Nice build JR. Almost couldn't find your thread for all the bumped everlast threads today. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Nice build JR. Almost couldn't find your thread for all the bumped everlast threads today.
Reply:nice work!Ya gotta spend money to make money!
Reply:Nice work
Reply:Nice work. Its a great way to protect your equiptment from being run into on a job site. How many hours did you have into it when it was done?KroekerMiller Trailblazer 302Miller Dial ArcMiller Suitcase 12RCVictor Torch
Reply:Originally Posted by welderShanenice work!
Reply:Another big LOOKS GREAT! I like that peeling slag, may as well have folks judge you by the tools you keep!past work toys; lathes,mills, drills, saws, robots, lasers ironworker, shears, brake, press, grinders, tensile tester, torches, tigs, migs, sticks, platten table, positioner, plasmas , gleeble and spot. Retired June 30, 2009.
Reply:JR, cage looks good, I have a smaller machine on a skid and I like the weld on D rings like for truck tow hitch plates, plenty strong for 2 or 3 SA 200's and won't need shackles unless you are using steel chokers.Also fall flat when not in use. That 3rd bottle , I can't make out what it is, are you running a suit case with hard wire and gas off the SA, I would like to try mine like that some time, or maybe your DC tigging? Got to love the SA 200, deserve all the love and care you can give them. Wish they were CV ."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:Originally Posted by wesdavidsonAnother big LOOKS GREAT! I like that peeling slag, may as well have folks judge you by the tools you keep!
Reply:Originally Posted by jreynoldsweldingYou got it, Suitcase off the the old lincoln and running 75/25. I like D rings too, but I am cheap.
Reply:Stickman, My LN-25 has a CC/CV setting on it, just set to CC and and it works pretty good, really cant weld small stuff with it(cant turn it into the lower settings). They make a CV Adapter for it but that thing is a $1000 bucks!You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:JR. do they still make the CV adapter for them or are they obsolete? also if you get a chance can you snap a picture of a MIG weld with gas off the SA200. I have a LN-25 but I think I have to change guns to run MIG think I have a K-126 Flux core but that's from memory."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:My Super S32P has a CC/CV switch also, but its never been used because I always had CV. I knew about FCAW with bigger wires on CC, I just never heard of solid on CC. I actually would have lost that bet! I never knew it was possible."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Kolot, if you have a FCAW only gun, and the K126 I believe IS FCAW only, then yes you will need a mig gun."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by kolotJR. do they still make the CV adapter for them or are they obsolete? also if you get a chance can you snap a picture of a MIG weld with gas off the SA200. I have a LN-25 but I think I have to change guns to run MIG think I have a K-126 Flux core but that's from memory.
Reply:Just curious , but how did you set the machine inside the frame after already being built ? And with the bottles do you have to lift them out the top, or is there room to manuver them out the side?safety last
Reply:Originally Posted by CheneyKidJust curious , but how did you set the machine inside the frame after already being built ? And with the bottles do you have to lift them out the top, or is there room to manuver them out the side?
Reply:Wow that turned out niceYa gotta spend money to make money!
Reply:Just FYI: 1 yr later the skid works great! If your application fits build one. Attached ImagesYou have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Originally Posted by jreynoldsweldingJust FYI: 1 yr later the skid works great! If your application fits build one.
Reply:Originally Posted by BistineauThe skid works great, but what happened, did the SA 200 play out? That's not like them to do that |
