Stick welding 1/8" wire
发表于 2021-8-31 23:31:25 | 显示全部楼层 |阅读模式
Not much of a project, but I needed to repair one of our steel wire reindeer from last year. Surprisingly I was able to use 3/32" 7014 at 80a to weld it! Ok, well it was more of a glob/fusion weld  Attached ImagesAC-180 Lincolnwelder circa '50's
Reply:Sweet!!HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Thanks, I was fairly impressed by my new welding skills, but it still falls under the "A grinder and paint will make a welder what he ain't." category :O Thanks for looking.AC-180 Lincolnwelder circa '50's
Reply:Pretty good since the filler was almost as big as the job.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-26 14:01 , Processed in 0.097389 second(s), 18 queries .
