Inverter stick out of position?
发表于 2021-8-31 23:31:24 | 显示全部楼层 |阅读模式
Forgive me if this is a stupid question. There have been advances in welders since I welded 24 years ago. I am looking to get a stick welder to augment the Lincoln 140 wirefeeder. I used an AC buzzbox back in the day but always prefered DC. I see they have these "inverter" welders now which are "DC" right?Can you switch polarity on them to weld out of position? (told you it was a stupid question)
Reply:Most of the inverter stick welders will be DC only.  Just switch the leads to change polarity.The ESAB MiniArc 161LTS is a cute little welder if that's big enough for you."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Scotsman1886Forgive me if this is a stupid question. There have been advances in welders since I welded 24 years ago. I am looking to get a stick welder to augment the Lincoln 140 wirefeeder. I used an AC buzzbox back in the day but always prefered DC. I see they have these "inverter" welders now which are "DC" right?Can you switch polarity on them to weld out of position? (told you it was a stupid question)
Reply:All inverters are dc welders. The real expensive ones are also ac welders with high frequency start for aluminum tig welding.I never switch polarity for out of position for stick welding. Dc+ ( reverse ) polarity for all my stick welding.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeAll inverters are dc welders. The real expensive ones are also ac welders with high frequency start for aluminum tig welding.I never switch polarity for out of position for stick welding. Dc+ ( reverse ) polarity for all my stick welding.
Reply:Originally Posted by Scotsman1886I see they have these "inverter" welders now which are "DC" right?
GMT+8, 2025-12-26 14:01 , Processed in 0.075561 second(s), 18 queries .
