scored a bunch of old school tools free... what is all of this stuff?
发表于 2021-8-31 23:31:24 | 显示全部楼层 |阅读模式
Not sure what some of this stuff is but here's a short list. is any of this stuff worth keeping/ using?Miller ac arc buzz boxmiller hf15 high frequency boxskil table sawcontinental international 16spd drill pressdunlap metal moving arm cut off saw with no motor attachedmakita routerryobi routerWeld craft tig torchother brand heliarc torchvarious leads for arc and tig weldingPancake air compressor harbor freight maybevarious regulatorsvarious ac motorscraftsman crescent wrenchesusa made impact wrench and nailersnap on voltmeterusa made dremelmakita die grinderetc...
Reply:That's a lot of cool free stuff!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:can you guys tell me what the regulator and gauges are on the first picture?
Reply:would love to have that power hacksaw... "LUCKY!"There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by petrochemproscan you guys tell me what the regulator and gauges are on the first picture?
Reply:The hacksaw is cool. ill have to figure out how to get the motor mounted
Reply:It's all useless, and dangerous. I'll be over tomorrow at noon to pick everything up. I wont even charge you.Motorboating...in the Cleavage of the Tetons
Reply:Originally Posted by petrochemprosThe hacksaw is cool. ill have to figure out how to get the motor mounted
Reply:If i wasn't in a rent house i would have already constructed a large table saw add on table as well as a router table and a chop saw bench... for now I'm gonna degrease everything maybe steel wool the rusted bits. repaint the items that need itand give everything a light coat of moly grease. the saw needs to be mounted and ill have to find the correct length belt to drive it after. i have a plethora of 120 and 220 motors but i have no idea what rpm or drive pully size it needs.the drill press was slightly seized up and after hand cranking it up the motor churned to life. it shakes a bit so i will rip the case off and the drive assembly down clean it all up. replace belts and give it a whirl.there is also a craftsman usa made scroll saw missing the blades ill have to check out. I may rip the cover off of the hf unit and see if the internals need cleaning. then ill steel wool the outer cover and repaint it when i do the arc unit. i know its overboard on this old stuff but i like my stuff looking nice and clean.i wish there would have been more hand tools since I'm dying to move my china harbor freight junk out and replace with quality steel forged tools.
Reply:if you do not want the carbon arc  torch you can send it my wayMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by WookieWeldingif you do not want the carbon arc  torch you can send it my way
Reply:Most of that stuff is garbage. You should probably send it to me.Big F**king HammerJumper cables & 2 marine batteriesJaws of life
Reply:I have the exact same Miller welder. Not too bad for 100 pounds worth of Modern Industrial Art. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by petrochemprosIf i wasn't in a rent house i would have already constructed a large table saw add on table as well as a router table and a chop saw bench... for now I'm gonna degrease everything maybe steel wool the rusted bits. repaint the items that need itand give everything a light coat of moly grease. the saw needs to be mounted and ill have to find the correct length belt to drive it after. i have a plethora of 120 and 220 motors but i have no idea what rpm or drive pully size it needs.
Reply:Its all junk, get rid of it immediately before it causes you great grief and problems in your life!  To help aid you in preventing this potential grief from creeping into your life, I can send a shipping crate to you where as you load said crate with all items and then promptly shipping crate to me for disposal of all items!  Hell, I wont even charge you fees for my services!   All joking aside, you done good, real good!  A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Originally Posted by ThorsHammerwould love to have that power hacksaw... "LUCKY!"
Reply:ok Im pretty sure one of the motors is a 1740 rpm and a 2" drive pully... ill have to wire it up and see if she runs.
Reply:if you are not famiar with oxygen regulators take head in the followin, DO NOT PUT ANY OIL OR PETROLEUM ON IT! can go boom. Also if you hook it up to try it, and you should, do not put your face in front of the dials when you open the gas bottle, when you open the gas bottle do it slowly. Might be a good old guage, might be toast as the diaprams will dry out over time, but for free, how can you complain."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-26 14:01 , Processed in 0.106078 second(s), 18 queries .
