Argon Regulator fittings help
发表于 2021-8-31 23:31:23 | 显示全部楼层 |阅读模式
I need some help finding out what type of fitting adapter will go in my argon regulator to attach my weldcraft 45v10r braided gas hose.  I'll attach a few pictures with some measurements and hopefully someone will be able to help me out.  Thanks a lot - Art the gas hose comes with one fitting attached to it to hook to the power block adapter , but the other end doesn't come with anything on it , so ill need a barbed fitting or something."I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:Sent from my Galaxy Nexus using Xparent Skyblue Tapatalk 2 Attached Images"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:the female fitting is crimped into an old hose , but I cant use that one.  need a new fitting - thanks , just point me in the right direction , or if u know the exact part # that would be appreciated"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:im tempted to cut the old hose and get the correct size double ended barb fitting and clamp the old hose to the new hose , but the old fitting is on an hold machine torch assembly and I don't wanna cut / mess it up , kinda neat looking"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:Your LWS should be able to fix you up. Round here, Indiana Oxygen carries all those fittingsSafety 3rdGump
Reply:1/4 or 3/8 flare fitting Probably 3/8Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:To me it looks like a B oxygen fitting."Most" inert flow equipment uses CGA 032.If the fitting in the regulator has a metered orfice then just re-use your hose end fitting.
Reply:the output is most likely 3/8 female flare you can by all kinds of brass adaptersBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:ok this is turning out to be a nightmare , I went to my local LWS store (Haun ) 50 miles away today .  They pretty much told me I got the wrong gas hose , that I don't need it and that I needed to buy one of their hoses to make it work , and that I didn't need the hose I bought (this was after they told me they didn't have the correct size fitting I needed) .  The outlet of my regulator has a fitting in it that is 1/4 npt x 3/8 compression male threads.  I have gone to lowes , my local plumbing supply , an electrical supply that had fittings , no1 could figure it out. if I removed the fitting that was in the regulator there is a small orifice in the end that is screwed into the regulator ; im guessing that needs to be there for a reason ?  im only asking because I found a 1/4 x 1/8" barb fitting that will work perfect if that orifice fitting isn't in there , but I bet it needs to be there.  thanks - art if I could only find a female 1/4 x female 3/8 compression coupler I would be set"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:Is this the fitting your looking for? Attached Imageswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:This is the one that fits most of the regulators I have here.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:A few more pictures that may help. The barb is for 1/4" id hose Attached Imageswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:thank you for the pictures , I finally got it , I ended up just saying frig it and cut the old rubber hose the with the right fitting on it for the regulator and connected the old hose and the new hose together.  This new hose that I got is really thin stuff , but supposed to be high quality stuff . so my setup is Weldcraft wp-17v-25R , 105z57 power block adapter , weldcraft 45v10R braided gas hose (1/8" ID), connected to that argon regulator , most likely I will purchase that flowmeter seeing as that seems like a great deal.  I'm guessing seeing as a few people have that brand the quality is pretty good ? thanks a lot - ArtLast edited by thinktwicez71; 06-20-2013 at 11:08 PM."I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:mechanic416 , if the barb was 1/8" that would be it !!!"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:I got it all together and bubble tested it all , no leaks , so for the time being until I get the new flowmeter this is how it will be used !"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
Reply:If it is a flow GAUGE the outlet fitting will have a metered orfice.If you remove the metered orfice you no longer have a flow gauge.
Reply:I bought that HTP flowmeter today , thanks again , that's a really good price , lets hope its a quality part and not a sign of the price ."I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
GMT+8, 2025-12-26 13:59 , Processed in 0.096344 second(s), 18 queries .
