Low buck tubing notcher reviews?
发表于 2021-8-31 23:31:22 | 显示全部楼层 |阅读模式
Im looking at picking up one of there notchers, curious to see if there are any  members that own one with a review to share?ThanksMillermatic 252Miller Syncrowave 200 Hypertherm powermax45Miller Trailblazer 275Miller 30A Spoolgun
Reply:Work well.  I had one for several years. Sold it because it got a notcher  for my ironworker and a tn-100 tube notcher(holesaw).  The low buck can wear you out if you have much to do.  However, it does work well.  You can do angle notches too, however you have to deterimine the angle then saw the notch. I felt if it is on the saw why not finish it there.   Ironically,  99 percent of the time I use my horiz. band saw to create notches for the rails I build.  I have never used my tn-100. to notch rails.I can even notch with my porta band in a pinch.
Reply:http://weldingweb.com/vbb/showthread.php?t=36108
GMT+8, 2025-12-26 13:59 , Processed in 0.111413 second(s), 18 queries .
