Yeswelder mig 250 pro
发表于 2021-8-31 16:58:44 | 显示全部楼层 |阅读模式
Decent welder? Looking for a mig setup that is 500-550$. Saw the yeswelder but never heard of them.Thanks for any input
Reply:Hard pass. I have one and can attest that it is not a 250 amp machine. Maximum output when using lift tig is 209 amps. I have measured voltage and amperage in manual mig welding mode and it struggles to exceed 180 amps. Synergistic settings are mess. Everything that the panel displays seems 20% off including wire feed speed, which is consistent with values provided during testing. With that said, it does weld fine when setup properly.
Reply:How about the prime weld 180
Reply:Personally never used the Mig 180, but know a few who use them daily. Seem to be an excellent mig for the price point, and the warranty cannot be beat. I do own a Primeweld 225X, and can assure you the quality is much better than the Yeswelder product.
GMT+8, 2025-12-18 18:23 , Processed in 0.096381 second(s), 18 queries .
