miller mig problem
发表于 2021-8-31 23:31:20 | 显示全部楼层 |阅读模式
when using the mig during a bead the wire will swirl around by it self as it comes out of the gun this makes it extremely difficult to make a perfect looking bead..... its .035 wire n 0.35 tip.any theorys the feed is this http://www.millerwelds.com/products/...eries_feeders/and the power source is thishttp://www.millerwelds.com/products/...dimension_302/
Reply:check for a bent tip or diffusersounds like its draggin across something making it curlmaybe liner kinkedidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Sounds like it's time for a new gun liner to me.
Reply:the whole assembly is brand new straight from tweco hose liner n tips is it possible that the hose was kinked from shipping
Reply:Possible that the liner was kinked in shipping.Have you tried a different spool of wire?  Sometimes the cast on the wire can cause the situation you're encountering.Also, Miller makes a "wire straightner" for that feeder.  Attaches just before the wire enters the guide (before the first set of rollers).I'd also check the liner size.  That's a pretty big (and expensive) setup for running a steady diet of .035 wire.  The liner may even be sized to accomodate 1/16" wire.  Too large a liner will allow the wire to "flop around" in it, causing the problems you'r seeing.PS Went back and clicked on your first link.  See where the first link showed the 22A/24A whereas the second link showed the S74D as the feeder with the migrunner package.  The 22A/24A feeders (even the 24A with 4 drive rollers) is not quite as robust as the S74D.I have used both the 22A and the S714DX (Same feeder as the S 74 DX) with my XMT304.  Used with a Bernard Q300 (15') and a .035/.045 liner, I've never experienced the problems you're having.  Did your company swap out the Bernard (comes standard with the Miller feeders) for the Tweeco gun?  Check the liner.Last edited by SundownIII; 01-09-2011 at 01:05 AM.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:are you using a 1 pound spool of wire , like a spool gun uses .I forgot how to change this.
Reply:Originally Posted by SundownIIIPossible that the liner was kinked in shipping.Have you tried a different spool of wire?  Sometimes the cast on the wire can cause the situation you're encountering.Also, Miller makes a "wire straightner" for that feeder.  Attaches just before the wire enters the guide (before the first set of rollers).I'd also check the liner size.  That's a pretty big (and expensive) setup for running a steady diet of .035 wire.  The liner may even be sized to accomodate 1/16" wire.  Too large a liner will allow the wire to "flop around" in it, causing the problems you'r seeing.PS Went back and clicked on your first link.  See where the first link showed the 22A/24A whereas the second link showed the S74D as the feeder with the migrunner package.  The 22A/24A feeders (even the 24A with 4 drive rollers) is not quite as robust as the S74D.I have used both the 22A and the S714DX (Same feeder as the S 74 DX) with my XMT304.  Used with a Bernard Q300 (15') and a .035/.045 liner, I've never experienced the problems you're having.  Did your company swap out the Bernard (comes standard with the Miller feeders) for the Tweeco gun?  Check the liner.
Reply:Originally Posted by LawsonWeldingLLCare you using a 1 pound spool of wire , like a spool gun uses .
GMT+8, 2025-12-26 12:06 , Processed in 0.112022 second(s), 18 queries .
