how are these made
发表于 2021-8-31 23:31:20 | 显示全部楼层 |阅读模式
http://www.burlybrand.com/dragbars/B28-4023.aspxhow is the tubing welded...it i so uniform and smooth?  how can it be duplicated
Reply:Tig welded, then heat treated?UA Local 598
Reply:The middle section is formed on the ends. Special machine,  then TIG welded and electropolished or chromed.Machining and drilled on the handle grip portions. I doubt they were heat treated.Last edited by Donald Branscom; 01-09-2011 at 03:20 PM.AWS certified welding inspectorAWS certified welder
Reply:Pressed in & plugwelded. Then silver soldered & buffed.*chrome plated afterwardLast edited by WeldingMachine; 01-09-2011 at 05:05 PM.Reason: forgot to add *Buy American, or don't whine when you end up on the bread line.
GMT+8, 2025-12-26 12:06 , Processed in 0.090568 second(s), 18 queries .
