Idea for a backyard fire pit
发表于 2021-8-31 23:31:17 | 显示全部楼层 |阅读模式
Hope this quick sketched pic makes sense...... I'm wanting a backyard fire pit, yet one that takes the smoke up high and away from where people are seated around the pit. Would a design similar to this work sort of like a vent-a-hood in a kitchen, where it would channel the smoke up and out of the pit, or would the smoke probably just boil out from under the metal chimney instead ?The little red lines would be just small rod, angle iron or something to space around the pit and weld the chimney up above the actual fire pit.
Reply:Had  something similar to this at a hunting club where I used to visit and it worked well. Very little smoke reached the folks around the fire and only if a stiff breeze blew it out. There will be some heat loss with this design also but it still got plenty hot around that fire!StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:I wouldn't reduce the smoke as much as that sketch shows. you'd want it probably close to about 1/3 the size of the pit itself. if you restrict it to much you wont be getting enough smoke to go up it to create a draft. which is what keeps more smoke going up the pipe.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Take a look at the free standing, middle of the room, fireplaces that were popular in the 70's. Pretty much exactly like what you are trying to do outside. Attached ImagesLast edited by DSW; 11-18-2011 at 01:13 AM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWTake a look at the free standing, middle of the room, fireplaces that were popular in the 70's. Pretty much exactly like what you are trying to do outside.
Reply:this may give you an idea as to sizing the fire box to the fluethey say a 10-1 ratiohow an open fireplace works http://www.csia.org/HomeownerResourc...1/Default.aspxidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
GMT+8, 2025-12-26 17:26 , Processed in 0.135036 second(s), 18 queries .
