Snow Plow mount
发表于 2021-8-31 23:31:17 | 显示全部楼层 |阅读模式
I was asked to fix this up.  I got a new mounting plate with the plow.I cut all the sh*t off with a torch, then the portaband.   Start fresh.   I kept the crossbar on the bottom, it looked ok.Leveled both ways.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I had a piece of 4X4X 1/4 angle.  Just about the right length.    Todays tool is a Miller Passport.  Its a nice welder.  I was on 7 for volts and 7 for wire speed or full tilt 10 on volts and 85% for wire speed.  C/25 for gas.  .030 er70s-6.  I was scratching my azz trying to figure out the angles.  I cut em on 45s then adjusted them with a 4.5" grinder.  Its 1.5 x 1.5 x 1/4.Its the only blue machine I own. Settings.  Nice machine.  I was looking at Bernard guns today.I made quite a pile of scrap today.  Too many lefts....Last edited by David R; 11-15-2011 at 08:14 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Finito.Whaddyathink?  Willithold?David Last edited by David R; 11-15-2011 at 08:11 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:looks good.good to see that you can weld with any coloroften fancied a passport myself.... one day...how many hours did it take you?looks like something that needed "stitched" when they showed up with it.Last edited by gordfraser; 11-15-2011 at 08:41 PM.G
Reply:i just picked up a passport the other day myself. pretty nice so far. it looks like your vertical up could have used a little more filler. any particular reason for c25 over 100% co2 or something? good design.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:What kind of locomotive is going to push it?Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by turki just picked up a passport the other day myself. pretty nice so far. it looks like your vertical up could have used a little more filler. any particular reason for c25 over 100% co2 or something? good design.
Reply:Here is the overhead.   Blue welder = good.Voltage on 7 wire speed on 70  or  280 inches per minute of .030 wire and C/25.  Should be 140 amps  Machine plugged into 220.  Both pieces were ground to bare metal.DavidLast edited by David R; 11-18-2011 at 06:08 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Wow! That thing was a pile dude, nice repair. Looks like some head scratchin' math right yonder [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
GMT+8, 2025-12-26 17:26 , Processed in 0.105256 second(s), 18 queries .
