Motor Guard M-26 air filter mount?
发表于 2021-8-31 23:31:16 | 显示全部楼层 |阅读模式
I just purchased a Hypertherm Powermax 45 and I was wondering if anyone had any pictures or ideas on how to mount an air filter near the machine? I would like to keep it portable but I can't really think of a way to mount the Motor Guard M-26 filter aside from making an aluminum base for it to mount to. I tried finding pictures on welding web of a hypertherm 45 with a M-26 mounted, but I had no luck. Any ideas/pictures would be greatly appreciated.ThanksMillermatic 211Hypertherm Powermax 45 Miller Elite welding helmetA garage that is to damn small
Reply:For my 1250 I built a little cart for it to make it mobile.  I have a piece of angle iron coming up one corner that attached to a small plate that I anchored the mount to.  Pics might not be easy to tell, but hope it helps. Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Here's what I came up with to keep the plasma cutter portable. It added a little bit of weight but not a whole bunch. I used 1/8" alum and mounted the 20 micron air filter as well as the motorgaurd M-26 to it. I also put rubber pads on the bottom to keep it off the ground a bit. I wanted to have a 2 stage air filter to extend the life of the M-26 before entering the plasma cutter. Let me know what you guys think. Attached ImagesMillermatic 211Hypertherm Powermax 45 Miller Elite welding helmetA garage that is to damn small
GMT+8, 2025-12-26 19:07 , Processed in 0.220746 second(s), 18 queries .
