silly question...sorry
发表于 2021-8-31 23:31:15 | 显示全部楼层 |阅读模式
ok can someone please tell me the name for the thin bar/wire that is used in stuff like lampshades and other decorations? for anyone who doesn't know what i mean it is similar to a bicycle spoke but in a decent length, something that can be bent easily, i want to try some fun little art things but i haven't seen it anywhere and i wouldn't even know what to be asking for so if it has a name that would be great, thanks
Reply:round bar stock ??? local metal supplierMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:try gas welding rod from a welding supplier.  Easy to bend and copper coated.What you're talking about is support wire, I don't know if there's a definite trade name.Maybe piano wire too, but I've never worked with it.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by WookieWeldinground bar stock ??? local metal supplier
Reply:Originally Posted by dubl_ttry gas welding rod from a welding supplier.  Easy to bend and copper coated.What you're talking about is support wire, I don't know if there's a definite trade name.Maybe piano wire too, but I've never worked with it.
Reply:sounds like 1/8" round rod to me. very common. though I'm sure over there it'll be classified in meteric. maybe 2mm round rod.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Mechanic's wire?? Comes in a roll, mostly used to hold drop ceilings up.
Reply:Lamp shades and such are usually made of brass rod which you could get at the hardware store or use brazing rod, as mentioned, from your LWS. Also look at TIG filler rod at your LWS.My son made a lot of projects in college with brazing rod and brass rings, etc.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:bailing wire..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:You can get suspended ceiling hanger wire in 10' straight sticks, its easy to bend and about the diameter your looking for.
Reply:Another place to look for wire this small is at your local hobby shop where they sell RC planes, boats, etc. If I recall, they call it piano wire. Been awhile since I flew RC stuff.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:thanks everyone  it is more a rod i was talking about, not as flexible as wire but easily bent into shape by hand due to its size, i will look for the things you have all told me, thanks
GMT+8, 2025-12-26 12:06 , Processed in 0.098313 second(s), 18 queries .
