Welding method - how to get this?
发表于 2021-8-31 23:31:14 | 显示全部楼层 |阅读模式
Hi,I want to get some result equal to those in the photos. How and what kind of machine to use? I was thinking about CD welding machines but dont know if it is best way... Detail and bolt material - stainless steel 316L. Base 3mm thick. The most important things are studs without flange and their 10mm lenght and 2mm diameter. link with photos: https://www.dropbox.com/sh/kzj7or2m7mxgtjm/UbZzaRSvInThank you in advance for any help or ideas
Reply:Post the pictures here, allot of people (myself included) won't click on a link from someone new.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:The base plate is drilled and tapped to accept the threaded rod..Pic set 1 looks like they were silver soldered..Pic set 2 looks like they were just bottomed out and left as is....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by SquirmyPugPost the pictures here, allot of people (myself included) won't click on a link from someone new.
Reply:http://en.wikipedia.org/wiki/Friction_stud_welding--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:There is small problem - I don't want to have collar or burnt surface on the other side because it will be mirror polished then. Whether is it possible to use this technology in such small diameter studs?
Reply:I think capacitor discharge is the process you looking for, find some collarless studs or make themDeal with the mirror finish after some tests.. 3 mm seems thick enough , I used a CD machine some time ago but the back surface wasn't important and I didn't pay any attention to it.--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:I can't find on the market any collarless studs in size I was writing (2mm diameter, 10mm length). To use cd, studs have to have this small thing at the end that initiates process so I think, I can't make them on my own...
GMT+8, 2025-12-26 13:59 , Processed in 0.073880 second(s), 18 queries .
