The best certification?
发表于 2021-8-31 23:31:13 | 显示全部楼层 |阅读模式
What is overall the best certification to hold? And I am not looking for responses like "well it depends on what type of welding your into". Bar none what is the best certification in talks opinion? What is the cert that opens the most doors, makes the most money generally, and employers are looking for.
Reply:Cert in JB weld.. Only the best of the best can pass this test.
Reply:Originally Posted by adajroshoWhat is overall the best certification to hold? And I am not looking for responses like "well it depends on what type of welding your into". Bar none what is the best certification in talks opinion? What is the cert that opens the most doors, makes the most money generally, and employers are looking for.
Reply:down hill pipe 6g api (cross country pipe)and 6g pipe asme that would be stick and tig root for the asmeand it goes for anything you are going to have to certify for the employer before you can even weld anyway on anything coded so my advise is to find what you like and stick to it but then again it depends on what you want to do Different fields are different so you asked kind of a loaded questionthis type of post comes up atleast once a month on this forum and the answers are normally the sameLast edited by WeldorWes; 06-26-2013 at 10:06 PM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I think 6GR is a harder test, but that's just me..
Reply:adajroshoThe single certification that will open all the door is a degree in metallurgy. http://www.usnews.com/education/worl...-and-materialsGo large.Opus
Reply:Originally Posted by OPUS FERROadajroshoThe single certification that will open all the door is a degree in metallurgy. http://www.usnews.com/education/worl...-and-materialsGo large.Opus
Reply:The "best" certification is the one you need to get the job you want, I would guess.
Reply:Go with ASME. Find an employer who does that kind of work. Always a challenge, very strict quality control, and you'll never really build the same thing twice. Pay is usually higher than what the average "wire monkey" gets. Also you will learn a very broad range of processes and materials including titanium
Reply:Degree and a cert are two different things.   Yes, a degree in the above mentioned should open more doors,at the very least move u to the top of the stack of resumes.
Reply:When I first learned that you have to be certified by the company every time you start a new job, I gave up on bothering with certs out of pocket. I don't see the point, other than to make your resume look good I guess. Which isn't really a bad thing. If I had to choose, I imagine ASME IX would be your best bet. It covers high pressure pipe and I think there's a nuclear standard in there somewhere.But if you have a chance to get in a good welding engineering or metallurgy program, go for it.
Reply:AWS D1.1API 1104The two most common Certs.  There are alot more fancy and harder but these are the two basics.More is never enough.
Reply:Im with akabadnews. Certification means nothing. Pull one out to show to your hopeful boss and he will tell you he needs his own tests passed. Show it at a place that just wants a warm body and they will tell you that you are over qualified and wont hire you because you wont stay. I carry a card in my billfold that I got for passing a 6g pipe test for a refinery but I have never told or showed it for a job. Wouldnt spend the money on it . Let some company pay for it. Ha.
Reply:The only thing a piece of paper is good for is to wipe your A$$ with..................and maybe get you an interview and another weld test..........6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:The best $$$ maker?The bar examBuy American, or don't whine when you end up on the bread line.
GMT+8, 2025-12-26 13:59 , Processed in 0.097287 second(s), 18 queries .
