Anyone know where I can get a full oxy-propane setup for a good price? As it is more economical, and safer to use propane where I live.Montgomery Ward 250 amp AC/DC stickMastercraft 90 amp Mig- Flux Core
Reply:There are a few internet dealers that sell oxy-propane rigs. Realize that your oxygen use will be higher.I assume you realize that you cannot weld with oxy-propane, it's only for heating and cutting.
Reply:There will ba quite a few that will point out that you need special hose etc, but it does work if you find a normal set of regs and hoses. Acc reg will screw into the propane tank. Just need the correct tip. They say it will destroy the hose, but I have been using the same hose for years without issues. Definitely uses more oxygen.Bruce DeLaetHeavy Equipment Mechanic and Welder1948 SA-200 short hood1949 LincWelder 1801963 SA-200 red faceMiller S-32-P
Reply:If you are buying a oxy-propane setup, it certainly should come with the proper hose for propane.
Reply:craigslist,you should be able to get a fairly good set of gauges and a victor torch.Last edited by welderinwv; 06-30-2013 at 10:00 AM.
Reply:Originally Posted by k45There are a few internet dealers that sell oxy-propane rigs. Realize that your oxygen use will be higher.I assume you realize that you cannot weld with oxy-propane, it's only for heating and cutting.
Reply:For just north of $250., you can get a new Victor Performer propane torch kit with a rosebud. It should come with proper hoses.You can braze with propane or other Oxy-fuel torches. However, welding of steel is out. It isn't so much the temperature as where the hot spot occurs in the flame cone AND the fact that the combustion byproduct gasses (as and where they occur) will not provide the atmospheric gas shielding as does acetylene. For heating and safety, propane (etc.) rule."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder |
