Lathe stand
发表于 2021-8-31 23:31:09 | 显示全部楼层 |阅读模式
Atlas lathe picked up from a swap meet for $600 Attached Images
Reply:Nice!  I have a Clausing lathe about the same vintage, waiting for a bit of derusting and paint.  What kind of primer / paint did you use?
Reply:Originally Posted by karlgabelNice!  I have a Clausing lathe about the same vintage, waiting for a bit of derusting and paint.  What kind of primer / paint did you use?
Reply:Similar to the one I just built for my craftsman/atlas lathe I will have pics up soon.... looks nice.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:$600......bastardio!  That be $2000 at least up here on the island!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:I got mine for $550Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:You now have opened up a whole new world having a lathe.You list of projects has just gone way up.Start scrounging up metal you will find a use for it and will be happy you did. I had this brass shaft (with a slight bend in it) for years and just made an adapter for a new tig torch for a short section of it.have funTom Attached Images
GMT+8, 2025-12-26 17:26 , Processed in 0.186622 second(s), 18 queries .
