Hydraulic Tube
发表于 2021-8-31 23:31:05 | 显示全部楼层 |阅读模式
Anyone know what kind of steel hydraulic tube is made from? From the pics it looks like coated steel but may be stainless. The factory weld has started leaking and ordering a new part will take days. Need to get it fixed tonight. Attached ImagesAirco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:The possibillities are almost endless for what type of alloy. Check with a magnet, if it is stainless most likely 316 but could be 304. Looks like a piece of european equipment many different steel alloys used for tubing.
Reply:Originally Posted by leightrepairsThe possibillities are almost endless for what type of alloy. Check with a magnet, if it is stainless most likely 316 but could be 304. Looks like a piece of european equipment many different steel alloys used for tubing.
Reply:I doubt that is anything crazy some e70s if it is not stainless, should do it. It is a pressure line though so you will need to prep the weld area properly. V it out clean really good, and do it off the machine.
Reply:Originally Posted by leightrepairsI doubt that is anything crazy some e70s if it is not stainless, should do it. It is a pressure line though so you will need to prep the weld area properly. V it out clean really good, and do it off the machine.
Reply:Pull harder on the wrench LOL. there is an oring in the flange right by where it looks like you need to weld. Plus you will need to Vee out the crack grinding dust is not real compatible with a hydraulic system.
Reply:Originally Posted by leightrepairsPull harder on the wrench LOL. there is an oring in the flange right by where it looks like you need to weld. Plus you will need to Vee out the crack grinding dust is not real compatible with a hydraulic system.
Reply:Originally Posted by SquirmyPugWill tell him to hit the wrench with his purse to break it free
Reply:Whatever it is just use 309 and call it a day.Universal filler for unknown alloys......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterWhatever it is just use 309 and call it a day.Universal filler for unknown alloys......zap!
Reply:Originally Posted by SquirmyPugIf I had 309 I would use it, none of the lws carry 1/16" 309 around here. They have 3/32" and 1/8" but would have to order 1/16" and I would have to buy 10lbs of it. At $13-14 (IIRC) per pound I don't want to buy it.
Reply:Originally Posted by smilexelectricToo bad you don't live closer I could hook you up with some 309 1/16" filler no charge.
Reply:Got the tube fixed, I took some pics but the camera wouldn't focus well and the flash made the weld too bright to see.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugGot the tube fixed, I took some pics but the camera wouldn't focus well and the flash made the weld too bright to see.
Reply:Few of the better pics. Pic 1- Cleaned with acetone and sandblasted. Ground out the holes before welding Pic 2- Welded Pic 3- Wire brushed and ready to go Attached ImagesLast edited by SquirmyPug; 07-01-2013 at 07:50 PM.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:I see Sally finally hit it with her purse hard enough to get it of the equipment.  LOL
Reply:Originally Posted by leightrepairsI see Sally finally hit it with her purse hard enough to get it of the equipment.  LOL
Reply:Looks like a nice clean repair - thumbs up Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-26 17:29 , Processed in 0.093279 second(s), 18 queries .
