查看: 2|回复: 0
D 1.8 Seismic Welding
发表于 2021-8-31 23:31:04 | 显示全部楼层 |阅读模式
does anyone have any photos or examples of using this code?  earthquake related structural designs regarding welding?  Im curious the changes that are made since the northridge quake and how the design of plating and has been changed to prevent cracking of critical components.
Reply:Here's a summation from Lincoln Electric that was put together for fabricators needing to comply: http://www.lincolnelectric.com/asset...ature/c165.pdfI don't work to D1.8, but a number of the structures we fabricate are to D1.1 with design to AISC 341, which is their seismic Code.  From a fabricator's standpoint, there isn't a lot that's different.  From the Engineer's perspective, a lot of it is additional detail - noting which welds are demand critical, specifying removal areas for attachments/backing, reinforcing fillet welds, beam clip shapes, etc.  From a welding materials perspective, there's also very little.  WPS's are often qualified with impacts (I won't even get on my soapbox there,) but filler material has a not-too-rigorous impact requirement that many off the shelf products can meet.
Reply:I couldnt believe how bad Lincoln wire took the heat for those jobs. I mean I understand it, but that is so much welding cover such a large area.  Crazy what a little aluminum can do.
Reply:I have done "seismic" welding in a nuclear plant.  What this consisted of was welding more intermittant beads or reinforcing of previous beads so that they are strong enough to withstand the movement of a typical earthquake, all to a spec. designed by an engineer and inspected by qc inspector, all 7018 stick."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
GMT+8, 2025-12-26 14:01 , Processed in 0.070651 second(s), 18 queries .
