Welding mild steel to stainless
发表于 2021-8-31 23:31:03 | 显示全部楼层 |阅读模式
What is the best way to weld a mild steel plate to stainless plate?  I've got a mig with standard wire and stainless wire, and a tig machine.Which should I use? This isn't going to be structural; I'm building a safe and want to have some torch protection.
Reply:Whatever machine is plugged in I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:The "mild steel" part of your question is easy, but there are about 927 different 'stainless' steel alloys (give  or take    ).Some stainless steels are easily welded, some are weldable with some difficulty or 'special' procedures, and some are pretty much unweldable.You really have to narrow it down for us when you say "stainless steel".That said, if you are trying to weld mild steel to something like 'plain' 304 stainless and you really don't care about corrosion resistance, single-pass you could weld them together with mild steel filler or 308 filler or 309 filler.  The best laid schemes ... Gang oft agley ...
Reply:Thanks for the replies, guys.It will most likely be 304 as it is readily available here locally, and not too ridiculously expensive (as far as stainless goes).I'm not really concerned about corrosion resistance, since the safe will be stored indoors, and painted internally and externally, plus I'll be using an internal atmosphere dryer.
Reply:startin to sound like a gun safe..
Reply:309 fillerwww.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:I've read 309 and 316 are good. I've used 308 and it welded, not sure if it was ideal or not though.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by weldbeadstartin to sound like a gun safe..
Reply:Originally Posted by weldermikeWhatever machine is plugged in
Reply:Any filler will work to weld the ss to mild steel plate. However, if you want the weld itself to be stainless, you must use 309 filler.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-26 15:47 , Processed in 0.108423 second(s), 18 queries .
