Found this manual while surfing, I think castweld is going to love it!http://www.knucklebusterinc.com/down...ing_Manual.pdfMatt
Reply:MattI've read many old welding publications, but not this one. Skimmed through the cast iron section-- and yes thats information thats still in use! Tractapac (Simon) could use this to repair his waterpump problem.ThanksPeterEquipment:2 old paws2 eyes (that don't look so good)1 bad back
Reply:Matt - nice find, that one's a keeper!"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Very cool.Thank you!
Reply:Good One! Thanks for the post.Now that's what should have been required reading in school; not Farm Animal and that other mush. We didn't need to read about agendas in no stinkin' barnyard parable to recognize what cooks.Although there were a few important things they could've just plain laid on the line for us, the way this book does. For example, how to properly de-carbon an engine using an oxy-acetylene torch through the spark plug hole, without melting the piston. Good LuckLast edited by denrep; 09-09-2010 at 01:15 AM.
Reply:Originally Posted by denrepGood One! Thanks for the post.(snip)Although there were a few important things they could've just plain laid on the line for us, the way this book does. For example, how to properly de-carbon an engine using an oxy-acetylene torch through the spark plug hole, without melting the piston. Good Luck
Reply:Whoaa you guys never used oxygen to clean carbon??? Works pretty well, especially on old 2 stroke mufflers that cant be taken appart.
Reply:Originally Posted by makoman1860Whoaa you guys never used oxygen to clean carbon??? Works pretty well, especially on old 2 stroke mufflers that cant be taken appart.
Reply:Matt;Thanks for that post, and I'll find it usefull to be sure.
Reply:The three sections of aluminum welding are very valuable; info here I've not seen in modern texts!Great find Matt - thanks for sharing!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Boy I am getting old I can remember seeing many of those pictures and text in shop classCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Many more like it are out of copyright and available here for free download at the Internet Archive:My bookmark below contains the "welding" search query. Different downloadable files are available including the Lorn Campbell manual:http://www.archive.org/search.php?qu...iatype%3Atexts
Reply:That's a great resource. Thank you!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Matt,Outstanding! This is going to be a great resource.
Reply:Originally Posted by farmallMany more like it are out of copyright and available here for free download at the Internet Archive:My bookmark below contains the "welding" search query. Different downloadable files are available including the Lorn Campbell manual:http://www.archive.org/search.php?qu...iatype%3Atexts
Reply:Here's a classic. So little has changed in terms of OA equipment.Some impressive casting repair:http://www.archive.org/details/autom...ldin00dunhrichRailroads were the equivalent of airlines back then, and both the rolling stock and support equipment were highly sophisticated. Before electric handheld power tools were common, pneumatic motors were often used. Some amazing gas welding repaired boilers, castings...http://www.archive.org/search.php?qu...iatype%3AtextsLast edited by farmall; 01-21-2011 at 08:54 PM.
Reply:Yes the site is GREAT and very useful IF you can get the documents for dowload in pdf form... not google-pdf !I can't seem to find how to download the google-pdfs - without someone asking me to pay money!Up your's Goggle!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick VYes the site is GREAT and very useful IF you can get the documents for dowload in pdf form... not google-pdf !I can't seem to find how to download the google-pdfs - without someone asking me to pay money!Up your's Goggle!
Reply:I've been downloading standard pdfs from there for years. If for some reason you run into one that is hosted by Google.http://www.aboutonlinetips.com/google-books-downloader/I suggest the Firefox Greasemonkey script. Free viewers for the other formats are also available.Last edited by farmall; 01-21-2011 at 10:08 PM.
Reply:Which book? I'll retrieve it as an example in different formats.More book archives:http://onlinebooks.library.upenn.edu/archives.htmlLast edited by farmall; 01-22-2011 at 08:38 AM.
Reply:Hey farmall, thanks for the tips on http://www.aboutonlinetips.com/google-books-downloader/for how to download Google books.Having read all that... Yikes!The problem is that each of the 5 or so ways listed to do it requires a complex set up process of installing several programs - before you can begin to download any google-book.Some like Greasemonkey script (rated the best) even require changing your browser to firefox.Sorry, I just find it all too darn demanding... especially compared to just clicking on the pdf files I want.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:MOST of the files are downloadable as straight pdfs. Once more, >>>WHICH ONE>>WHICH ONE<<< did you have trouble with?BTW, Firefox is incredibly usefull and doesn't mean getting rid of IE. It has addons available for free to print to pdf, block adverts, block popups?Firefox also has a free EPUBReader extension that allows reading EPUB formats online or from local files:https://addons.mozilla.org/en-US/fir...on/epubreader/Firefox is amazingly capable, there is no downside to trying it. Here's a Portable version you can run from its own folder on USB key or locally. To backup, copy the whole folder, bookmarks, extensions, preferences all preserved.http://portableapps.com/apps/internet/firefox_portableYou may find different books display better in different formats, so experiment!----------------------------------------------------------Oxy-Acetylene Welding and Cutting Downloads as an HTML file only, so save as HTML and open with any browser. Alternate: Save the zip file 8oxac10h.zip, unzip it, and open the htm file with any browser.If you don't have .zip extraction software on your PC, here's an Open solution:http://www.7-zip.org/download.html-----------------------------------------------------Oxy-acetylene Welding Practicehttp://www.archive.org/details/oxyac...ewel00schogoogSave EPUB to your computer, either open with Firefox with EPUBReader installed, or select from one or more off the listed readers.I like Calibre for a standalone reader:http://calibre-ebook.com/http://en.wikipedia.org/wiki/EPUB-----------------------------------------------------http://www.archive.org/details/oxyac...ewel00socigoogAs above, but since both have djvu options, here's a decent standalone djvu viewer:http://sourceforge.net/projects/windjview/Explanation of djvu:http://djvu.sourceforge.net/These formats will become more common in the future, but free info is free info, and the software is free with no malware.Feel free to post questions!Last edited by farmall; 01-22-2011 at 10:32 AM. |
