查看: 13|回复: 0
couple of t joints feedback please
发表于 2021-8-31 23:30:56 | 显示全部楼层 |阅读模式
ive been in the welding program at my highschool here is a couple of t joints i did with a 7018 on 70 amps Attached Images
Reply:Looks good overall, but you might want to work on your consistancy some, and turn that welder up a little.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Lanse is right, 2nd pic is a bit cold.  Give it some more heat.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by MarkBall2Lanse is right, 2nd pic is a bit cold.  Give it some more heat.
Reply:Yes, give it about 10 more amps & watch the puddle to "wet in" on the toes (flat & vertical surface).  While you are welding, watch the puddle, if it doesn't "wet in", pause a half second so it does.  The puddle may need to be "stirred" a little bit with manipulation of the puddle with the end of the rod.If you use the same amp setting, slow your movement a bit.  You will be able to see how the metal flows by watching the puddle.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:ill do that thank you
Reply:Welds look good. One thing to remember is that every machine is different and 70 amps on one machine may not run like 70 amps on another. You might have to play with the amperage quite a bit to get the results you want. Just something to keep in mind when switching between machines. Keep up the good work and practice, practice, practice.Cain's Mechanical LLC Southwick, MAwww.cainsmechanical.comRig:-2006 Chevy 2500 utility body-Lincoln Ranger 10-Miller Spectrum -Tons of hand and power toolsAWS D1.2 Structural Steel Certification
Reply:Try the 7018 3/32 between 85 and 95 amps.UA Local 598
GMT+8, 2025-12-26 14:30 , Processed in 0.185834 second(s), 18 queries .
