90 foot boom for a mine in Arizona. two large shaft stands built for a mine in Mexico.large crusher gear i had to build up the bearing diameter for machining. Attached Images
Reply:more of the crusher conveyer shaft then the finished product with the new bearing on then this the aluminum seal for the pillow block they tried pursuading it with a hammer and chunked it so i built it up and they machined it back to new. Attached Images
Reply:and the machined and installed product Attached Images
Reply:What process did you use on the shaft??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:That roller bearing is badass lolWelding/Fab Pics: www.UtahWeld.com
Reply:I started with two burners sitting on it for four hours to get ot up to 650 deg. Then once I started welding I welded continues for 13 hours using 1/16 71 t1. I had to stop about every two hours to warm it back up. I used two rolls of wire and two bottles of co2. Then I used seven 100# bottles of propane.
Reply:Originally Posted by MikeGyverThat roller bearing is badass lol
Reply:i like the second pic with people standing around the best.people say i dont like work, but they're wrong. work fascinates me, i could watch it for hours..
Reply:Does Bfast mean what I think it does??? Like shipbuilders of the Titanic???What are you doin' projects in the AZ?
Reply:Nice work, looks like fun.PeterEquipment:2 old paws2 eyes (that don't look so good)1 bad back
Reply:Originally Posted by Fabn4FunDoes Bfast mean what I think it does??? Like shipbuilders of the Titanic???What are you doin' projects in the AZ? |
