Some Current Work
发表于 2021-8-31 23:30:53 | 显示全部楼层 |阅读模式
Cage was done in a Nissan 180sxAlso did another cage and a removable front end on a S14 240sx.IC Pipes, Intercooler Mount & Downpipe on Bryan's EG
Reply:no close-up, no glory --------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:Originally Posted by RRebeloCage was done...Also did another cage and a removable front end...
Reply:Well the cage could be a bolt in conversion or a kit...   Looks really good.  And I love me a set of pie cuts.Also second to last pic... checking for leaks?And one more thing.. I think you guys put the steering wheel on the wrong side.  ;-) LOLJoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:i weld the cages and bend them using a jd2 32 converted to air over hdy. regarding close up of the welds i have a pic on my phone which i can try and upload later.i use it to keep the flange from warping while i was welding it, but i could use it to back purge the pipe if i wanted to.
Reply:phone didnt take the pic well, but im sure u get the point.
Reply:I got the chance to build this current setup on a 2.3L mazda. i must say i am happy with the end result & the customer seems to be on the same page.
Reply:Looks pretty good,what kind of material did u used for the turbo exhaust also is that engine in the EG a K20 swap?
Reply:i used sch10 for the exhaust manifold and yes it is a k20
Reply:Originally Posted by RRebeloI got the chance to build this current setup on a 2.3L mazda. i must say i am happy with the end result & the customer seems to be on the same page.
GMT+8, 2025-12-26 14:26 , Processed in 0.071321 second(s), 18 queries .
