You were right
发表于 2021-8-31 23:30:51 | 显示全部楼层 |阅读模式
I took some scrap 1/8" 304  stainless and welded it with no filler.  I went right along to keep the heat input low then did a root bend and a face bend.Outside corner weld fitup is good.Here are the results180* root bend1/16 tungsten approx 70 amps  Arcmaster 185  #12 cup WP20 torch, no gas lenz.DavidLast edited by David R; 11-30-2011 at 07:40 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:You meaning who?I,m guessing this test was to see if no filler no strength as i stated was correct?Glad i could help u out.
Reply:no offense but it looks like you had too much coffee this morning and got the jitters.
GMT+8, 2025-12-26 14:00 , Processed in 0.119504 second(s), 18 queries .
