Lincoln Invertec users
发表于 2021-8-31 23:30:46 | 显示全部楼层 |阅读模式
Quick question for all Lincoln Invertec stick/tig machine owners, have you ever performed the recommended "input filter capacitor discharge procedure"? I noticed they suggest doing this ever so often, yet they don't include the necessary resistor with the machine. Any ideas on the best place to pick up the resistor? Also, what is the reasoning behind this procedure? I picked up an Invertec V250-s several years ago, and primarily use it in the TIG function at less than 100 amps.  I've had this machine at least 6 years, and have never done the capacitor discharge.  Thanks!
Reply:Can't help, but I'm curious to hear the answer to your question.
Reply:From what I read in a manual, it's done before you work inside the machine so you don't zapped.  Caps will bleed down if the machine is off for a period of time."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I have a V250s and I think it did say to discharge for some reason other than service. Usually, lethal caps have bleed resistors but I dont remember if the 250s does.  In any case, if you want to bleed your caps, I suggest using an LED soldered to a resistor to bleed. The LED will light up and slowly fade out when discharged. Its safer that way.
Reply:Originally Posted by InsanerideI have a V250s and I think it did say to discharge for some reason other than service. Usually, lethal caps have bleed resistors but I dont remember if the 250s does.  In any case, if you want to bleed your caps, I suggest using an LED soldered to a resistor to bleed. The LED will light up and slowly fade out when discharged. Its safer that way.
GMT+8, 2025-12-26 14:00 , Processed in 0.096407 second(s), 18 queries .
