Miller bobcat 225g outlets
发表于 2021-8-31 23:30:43 | 显示全部楼层 |阅读模式
Hey guys I just picked up a bobcat 225g for a pretty good price. My question is referring to the 240v outlets. It has the 240 duplex outlets at 15 amps each. I wanna be able to run my miller 211 off the welder. It's will require max 25 amps. Can I either combine the plug wiring and wire in a 30 amp plug or make a pigtail that has duplex plugs to a female 240 plug. I want to be able to run my spool gun especially for boat hoist repairs. Is this possible without screwing anything up? Thank you in advance.Sent from my iPhone using Tapatalk
Reply:http://www.millerwelds.com/resources...30Amp-From-15aEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Very good! I've been searching google but never could find anything. Just what I was looking for. Thank you!!!Sent from my iPhone using Tapatalk
Reply:I searchedmiller bobcat 225g 240v outletsGot lucky2nd hitEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-26 14:00 , Processed in 0.091158 second(s), 18 queries .
