GMAW What Do You Think
发表于 2021-8-31 23:30:34 | 显示全部楼层 |阅读模式
Playing With Millermatic 211 - Useing Auto Set230V - .035 Wire - 75/25 Gas -  Looking For Comments Good Or Bad Attached Images
Reply:Bit hard to say since the camera chose to focus on the rear piece rather than the front one. I can't tell if I'm seeing undercut at the top of the front piece or not with it being blurry like that. The bead does look faily consistent despite the possible undercut.You should however do at least minimal prep and grind or sand off some of the rust before welding..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks DSW - The Rear Pic. Is A 6010 Stick Weld - Trying To Improve On That Also
Reply:I personally wouldn't use the autoset... I just don't see a reason for it.  Wouldn't want to find out by accident that it blows and I start getting burn through or anything.Looks pretty consistent, but like DSW said... can't really tell.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
GMT+8, 2025-12-26 15:48 , Processed in 0.069807 second(s), 18 queries .
