My First Weather Vane
发表于 2021-8-31 23:30:34 | 显示全部楼层 |阅读模式
This is something a customer ordered.  I never built one before, but it was fun.He wanted the corvette, peace symbol, and all.  I hope that he likes it.He plans on painting it himself.The bracket for mounting is so that it can mount on the peak of a roof.  It is octagonal in shape (gazeebo) and I don't know the pitch of the roof.  I saw these for sale online for 25-60 bucks.  Decided to make it myself and save the money. Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:a couple more or so Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Video.  If the link doesn't work, give it a few minutes.  The video is still uploading:The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Very cool. I have thought about making one myself. Your getting pretty handy with your plasma cutter
Reply:Originally Posted by forhireVery cool. I have thought about making one myself. Your getting pretty handy with your plasma cutter
Reply:Originally Posted by Mick120Nice work John.I make mine to a similar design but, also install an upside down candle cup with a hole drilled thru the center, then welded to the upper shaft just above the pivot.Helps prevent water entering and, might be something to consider.
Reply:jdh,The plasma cutting looks great, however the welds "hurt my eyes".I know it's going to be up on a roof where no one will see them, but somebody's still got to mount the dang thing.If this was done for a "customer", he deserves better.  Remember, your work will be judged by the worst bead, not the best.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by SundownIIIjdh,The plasma cutting looks great, however the welds "hurt my eyes".I know it's going to be up on a roof where no one will see them, but somebody's still got to mount the dang thing.If this was done for a "customer", he deserves better.  Remember, your work will be judged by the worst bead, not the best.
Reply:Originally Posted by Mick120I make my own.I used to have a supplier that stamped them by the thousands but, they went belly up so, I made my own dies and make them in the press as I need them.Cutting the circles in the plasma of course.....
Reply:Looks great. I have a metal shop nearby that will do CNC plasma cutting but I've never explored it.  How do they charge you- by the # of inches of cut? Total time? By the job?  And if you don't mind saying, what did you charge for the completed product?Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:PM sentLast edited by jdh239; 12-02-2011 at 12:00 PM.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Not sure how much you designed around it, but is it mounted to the shaft at the center of gravity? Did you do any calculations for the center of pressure. Just curious as I've seen similar one's made that just so happen to have the center of pressure in the wrong spot and have the wind vane turn in the wrong direction. Just have to be sure the center of pressure is always aft the center of gravity.
Reply:Originally Posted by BCTimberwolfNot sure how much you designed around it, but is it mounted to the shaft at the center of gravity? Did you do any calculations for the center of pressure. Just curious as I've seen similar one's made that just so happen to have the center of pressure in the wrong spot and have the wind vane turn in the wrong direction. Just have to be sure the center of pressure is always aft the center of gravity.
Reply:I would like to see someone make one of these.   Pretty cool lookingThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Would've looked a lot nicer if u had welded a 67'rs/ss camero on top but a good job none the less."Steel is weak. What is steel compared to the hand that wields it?"- James Earl Jonesmiller 225 w/ 3035spoolmate, Lincoln sq wv 275 w/radiator, hypertherm 600 plasma cutter, other stuff
Reply:Originally Posted by badknotWould've looked a lot nicer if u had welded a 67'rs/ss camero on top but a good job none the less.
Reply:Nice Job.Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
GMT+8, 2025-12-26 15:47 , Processed in 0.108570 second(s), 18 queries .
