Arctic cat cage aluminum
发表于 2021-8-31 23:30:31 | 显示全部楼层 |阅读模式
Just framed out.......... Attached Images
Reply:Looks good,what material did u used?
Reply:read the title T1000Lincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Looks good to me. What type of aluminum did you use?Tim Beeker.
Reply:Looks good, what alloy and type of tube?Welding/Fab Pics: www.UtahWeld.com
Reply:Looks good, what type of bender do you use? Secure your tanks to the wall so they dont fall
Reply:Are those Vern Lewis tanks?  They look like it to me, I work for them so I should know....looks good.
Reply:I would NOT want to be in that in a high speed roll over.That's what STEEL is for..It may look pretty but I have my doubts.When do you think Top Fuelers or Pro Stocks will go to aluminum?Never....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks good from here.   Close up of the welds?  What wall is the tube?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks awesome. I personally wouldn't have done it out of aluminum. Thats where i draw the line. I've passed on a few aluminum "cages". Not knocking you. i build hunting high seats and quail seats, that if used irresponsibly would be a million times more dangerous than that. I would be afraid of the almost parallelogram that it has going on. looks like it would fold flat easily. like this www.performancealuminumfabrication.com
GMT+8, 2025-12-26 14:00 , Processed in 0.214353 second(s), 27 queries .
