Can you ship a full argon tank
发表于 2021-8-31 23:30:25 | 显示全部楼层 |阅读模式
i was looking at a brand new argon bottle it's a 125 cubic foot tank full of 75/25 on ebayfor 300 bucks + shipping but i wanted to know is it safe to ship an argon tank.
Reply:I'd like to see the shipping costs- cause it ain't going normal carrier.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I think you could buy 125cf tank filled at your LWS for much less than $300.Tractor Supply would be more than LWS, but probably cheaper than $300 and you can pickup today.Where are you located?Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:The 125cuft Thoroughbred C-25 cylinders are currently $320 at our local TSC.  A bit much but you have the option of picking up a refill 7 days a week if needed which are a bit pricey at $50 for the same #4 cylinder.http://www.tractorsupply.com/en/stor...inder-handlingYou'd have to check with your LWS to confirm they'd refill it as many will.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You can't ship an empty tank through usps, and I really don't think anyone would allow you to ship one that is full.What are you going to do ship it back an forth everytime you need a fill? That's stupid.I'd buy 2 of these and be just under $125 cubic feet and keep $100 in my pockethttp://www.ebay.com/itm/55cf-Welding...item20cee6930cProblem with buying a tank online is finding someone that will locally fill it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I just bought a full 125 for $175.  Painted and perfect.  New date code.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255I just bought a full 125 for $175.  Painted and perfect.  New date code.
Reply:Post your location and maybe someone can point you in the right direction. My local suppliers are around  $ 195.00 to $ 225.00 for a 125 size .
Reply:Hello Mig welder95, two issues come to mind when you are considering shipping of a "high-pressure" cylinder. First being that it contains hi-pressure gas, this requires that it be shipped in an identified unit with appropriate placards. Secondly, although Ar/CO2 isn't flammable, it is a gas which can result in asphyxiation, thus it is special in that regard and requires the necessary considerations. Just these two things will likely require "special" shipping considerations and cause shipping to be above what you should/would like to be paying. As others have added, you are likely better off to purchase directly from you LWS or possibly off of Craigslist in your area providing you can receive proper documentation on the cylinder that you are purchasing to be sure that it isn't a rental bottle. Just my $.02. Best regards, Allanaevald
Reply:Originally Posted by BD1Post your location and maybe someone can point you in the right direction. My local suppliers are around  $ 195.00 to $ 225.00 for a 125 size .
GMT+8, 2025-12-26 14:10 , Processed in 0.094871 second(s), 18 queries .
