powermax 45 mobile case??
发表于 2021-8-31 23:30:24 | 显示全部楼层 |阅读模式
Im using my powermax 45 for mobile repairs,  i dont wanna beat it up while in my truck toolbox. Are there any members out there that have found a case that fits the plamsa cutter for safe transport?I have looked at some Pelican brand cases but would like to see if there are any other options out there i have missed before i pull the trigger.Thanks dannyMillermatic 252Miller Syncrowave 200 Hypertherm powermax45Miller Trailblazer 275Miller 30A Spoolgun
Reply:One thing I have enjoyed having on my TD plasma cutter is the tube frame it is in. The frame is not 100% cover for it but it does make the unit more durable portability wise.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:No hard case but a 127219 cover.....better than nothing I guess.
Reply:Originally Posted by jobpump53Im using my powermax 45 for mobile repairs,  i dont wanna beat it up while in my truck toolbox. Are there any members out there that have found a case that fits the plamsa cutter for safe transport?I have looked at some Pelican brand cases but would like to see if there are any other options out there i have missed before i pull the trigger.Thanks danny
Reply:Zero makes some nice Aluminum cases but they are $$$."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:The largest Stanley tool chest (about $70 at HD) will easily hold the PMX45 with the torch and have room left over. Might be bigger than you want, though. Instrument cases (Pelican, Anvil, etc.) are nice but not cheap. A custom cover made from canvas or vinyl will provide some protection and would be the most compact solution. McMaster-Carr has them.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:A Greenlee welders job box (small coffin box) should do the trick, lots of room left for supplies and accessories."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
GMT+8, 2025-12-26 14:00 , Processed in 0.095176 second(s), 18 queries .
