Projects waiting to happen
发表于 2021-8-31 23:30:20 | 显示全部楼层 |阅读模式
I have been really getting back into welding lately and noticed the price of steel has gone up a lot an dit has kept me from getting the welding fix I  have been looking forI used to get remnants at 25 cents a pound not its 69 centsA 20ft length of 1"x1"x.120" used to cost me around $20, now its $40But I probably don't need to tell you guys thisSo I have been following CL looking to get some materials, no deals so I waited some more and today I found a deal$60 for 1500 or so pounds of scrap steel (weighed it at the dump for grins) hardly any rust, just a little rebar,$40 for the welding table that the vice is on (has really nice casters)$40 for the 5" olympia vice (not the best deal but it was a package thing)$20 for assorted vice grips $50 for the heavy 3/4" topped tableWhat do you guys think? Attached Images
Reply:My dad brings back steel all the time; he hauls heavy machinery/equipment and most of the steel they use to temporarily hold in place until he delivers it,then it's given to him....so I get c channel, flat, square tubing etc all the time. The problem is its usually bent or twisted, and I have to straighten it before I can use it. He brought back a 8'x30' rectangular frame made out of 1/4'' wall 6'' square tubing, used to move a large pump on.... I think it weighs a little over a 1 ton....free......I think I'm going to use it for a foundation for a garage addition.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:I'm jealous of your remnant pile... Looks to be a pretty good deal.  I must find a place around me that does this.  The place I currently go is not big into remnants.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:That table with the 3/4" top is a great buy.   The wheels alone are worth more than $50
Reply:Originally Posted by joebieI'm jealous of your remnant pile... Looks to be a pretty good deal.  I must find a place around me that does this.  The place I currently go is not big into remnants.
Reply:Originally Posted by AZdevildogThat table with the 3/4" top is a great buy.   The wheels alone are worth more than $50
Reply:Originally Posted by ledbed6bThe casters on the little cart are also nice, they are $35 a piece newThe only problem with the 3/4" is that it is warped pretty bad, I need to figure out how to unwarp something that size, or just get it ground flat
Reply:Originally Posted by ledbed6bCL is the only way to go for me, the local steel yard charges 69 cents a pound so this would have cost me $1100 with tax to get it there
Reply:Originally Posted by BistineauHow about the plate on the bottom? It looks to be 3/4" too. If it's flat, take the wheels off & mount them to what's now the top and flip it over, problem solved. The next big decision now is what project to make out of all the other steel pieces. Will it all go into one or many? Could be a lot of new threads come out of that pile.
Reply:the assorted vice grip set isn't bad either. If you don't need them, hit me up Hobart Handler 125 #500495Miller Diversion 165 #907005 (tig learning box)
Reply:Turns out the bottom plate is 1 1/4" and the top is 1", no wonder its so damn heavyMy guess is around 800lbs its 2ft by 4ft or soThe bottom isn't warped near as bad so I flipped it over cut off the wheels and started sanding the surfaceAny suggestions on what I should use it for? Attached Images
Reply:Originally Posted by TeckniXthe assorted vice grip set isn't bad either. If you don't need them, hit me up
Reply:Good findBeen looking on CL for a long time but a lot of scrappers out there and i didn't find what i needed for my benchNeeded a bench tired of welding on my knees on the cement slab  and now with the temp dropping it really sucks at my ageThere was a guy who had a bench plate he got ground and not for a lot of money either http://weldingweb.com/vbb/showthread.php?t=62794Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-26 14:00 , Processed in 0.093700 second(s), 18 queries .
