need some tips on overhead
发表于 2021-8-31 23:30:15 | 显示全部楼层 |阅读模式
passed my bend test for flat , horizontal , vertical up , now im on to overhead im running 7081 HR1 rods at 90 amps and dig is 50 on a miller maxstar 200 as per instructor's request my beads look good there just shaky because I cant really brace myself .my instructor said plant my elbow and use it like a hinge and pull the stick to me it works but still a little off any ideas ?
Reply:tie a loop around the test stand with your lead, insert arm thru loop and steady your arm with the lead.
Reply:Clamp a vice grip on the jig and put your elbow on it.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I have class today at 5 ill report back and let you guys know how I did
Reply:Vise grip a piece of angle iron to the plate parallel to the weld to support your "left" hand (or pinky off it)XMT304 (school)SP125+ (home)HF 4x6 BandsawGood judgement comes from experience and much of that comes from bad judgement.
GMT+8, 2025-12-26 15:47 , Processed in 0.072263 second(s), 18 queries .
