查看: 2|回复: 0
Need oxy-propane hose sizing suggestions
发表于 2021-8-31 23:30:10 | 显示全部楼层 |阅读模式
I'm switching to oxypropane for heating and cutting use on the service truck.  This torch won't normally cut more than 1" thick steel, but will also be used with whatever Smith's smallest propane rosebud is.  It will be fed from a 100-lb tank on the truck.  The torch will normally run a 50' hose, which will be a grade "T".  I'm trying to decide whether I need to go up to 3/8" dia hose from 1/4", which is what I have used in the past with oxy-acetylene.  Occasionally I'll add another 100' of hose to it for those far-away jobs, and that hose will definitely need to be 3/8".  If I have the first 50' in 1/4", will I be choking the torch down too much when I have to add in the extra 100'?  Thanks for any input you may have.
Reply:tbone, all i run is oxy-propane and i run 1/4 at 175ft with no problem,but the secret is , as you stated is the smith torch. they work wonders with propane. i dont know how but they just do.btw that 100lb bottle is gonna last you a long time. i usually get 6 to 7 k size oxy bottles out of on 20lb barbq bottle.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Originally Posted by ksweldermantbone, all i run is oxy-propane and i run 1/4 at 175ft with no problem.
Reply:i usually run o thru 3 on tip sizes, low pressure setting 7-10, i do use a rosebud, and at the temp rite now here wich is10 F i ve only had a reg freeze up but that was once bout ten yrs ago, come to find out the reg shot craps anyway. oxy low pressure settings 25-30. heck i can cut thru 4'' plate with my heavy duty smith no problem, and best of all i havnt went thru a torch tip in about 6yrs, thats me only not talking about my helper ! its just so easy to clean the tips out bcause theyre two piece tips,best of luck. let me know if i can help any further kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
GMT+8, 2025-12-26 14:00 , Processed in 0.093248 second(s), 18 queries .
