Latest quickie log burner
发表于 2021-8-31 23:30:04 | 显示全部楼层 |阅读模式
Hi, All, Just a couple of pic's of my latest efforts, Made it for my niece as a christmas present.Fired it up to cure the high temp paint and it burned very well,You can't see on the pic's but with this one I fitted a secondary air feed pipe coming in at the rear,thro the fire and injecting hot air just before the flue baffle plate.This one is fitted with wheels and a pull-out handle for easy manoeuvrability. Even attached a "makers" plate and build date etc. Attached ImagesLast edited by gordon stephenson; 12-19-2011 at 07:01 AM.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Nice design for the door vent. Is the body of the burner a recycled tank? Lots of cool functional parts!
Reply:The main body is a propane tank, Surprising how thin they are, the thickness is around 1/8"Doesn't take long with the powermax 45 once i have rinsed out and purged the tank for a little while,Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Very nice. Comfortable way to get rid of logs. rather cozy for a spot of tea.   Mac
Reply:I've enjoyed your log burners that have been posted.My question would be about the amount of draw available through the door. It seems like the fire would get screaming hot with no way to control it or damp in down. The secondary air feed would even make it hotter.It would seem that the thin body would glow red. But since these are used outdoors maybe that is what is desired.
Reply:Hello GWD,                 I have not as yet had a fire that wanted to "run away" I had thought about it and was going to fit an adjustable baffle in the flue,But up to now it has not been necessary with any of the burners I have built. The flue pipe is only 3.1/2" outside dia with a 1/4" wall,so This seems to be the limiting factor with the combustion.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
GMT+8, 2025-12-26 13:59 , Processed in 0.112445 second(s), 18 queries .
