Finished mineral feeder!
发表于 2021-8-31 23:30:02 | 显示全部楼层 |阅读模式
OK so my previous thread "is 300 bucks toom much" ( check it out on my profile) i posted a pic of one that my uncle and dad and grandpa mad. Well i improved them a bit I stuck with the design like the oiler hangers but i have to models now. one has pipe that the hydraulic arms can go into the other one has an 8 1/2 inch sqaure it can go into. I also dont know if you can see it but the bottom half of the black one is painted in a truck bed liner to keep the salt thats in mineral from rusting it out. Theyre 300 dollars if you would like one I can work out shipping details later message me if you do want one. or email me at [email protected] Attached ImagesQuality is our policy.
Reply:are you going to put anything on the top to prevent water from getting into the buckets? The bed liner is a good touch.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:well you caan get a plastic roof but it usuall doesnt matter   here we get prolly an inch per storm but you just mix it with a shovel and its good as newQuality is our policy.
GMT+8, 2025-12-26 16:09 , Processed in 0.173231 second(s), 18 queries .
