Lincoln Arc Start switch electrical questions
发表于 2021-8-31 23:29:59 | 显示全部楼层 |阅读模式
Does this device simply leave the other 4 pins of the 6 pin amphenol connector disconnected?  Is the device a simple switch with nearly no resistance?  Basically, I'd rather start welding right away and I am waiting for my pedal to come in which may be a few weeks while its getting fixed ( Case issue).I know the K870 pedal has a 10k 2w pot and two caps in addition to the switch, but I see so no resistance or load value for the switch so I am assuming its just a normal switch but I don't know what amount of current it should be able to handle....
Reply:Yes, pretty much any switch will work. It only has to handle a few milliamps.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Thanks a lot!
Reply:I think you still need a pot to get current tho.  Im kinda thinking you have to switch to GTAW and REMOTE for Arc Start for TIG. Otherwise switch to LOCAL SMAW and set Local current for scratch start. LOCAL GTAW wont work and REMOTE wont without the pot in the foot pedal
Reply:Originally Posted by InsanerideI think you still need a pot to get current tho.  Im kinda thinking you have to switch to GTAW and REMOTE for Arc Start for TIG. Otherwise switch to LOCAL SMAW and set Local current for scratch start. LOCAL GTAW wont work and REMOTE wont without the pot in the foot pedal
Reply:Yes it worked just fine, the current switch and gas solenoid operation are on the same pins (D & E) so there is nothing to worry about if you just want to have arc & gas with no remote current control.  Honestly, it would take minimal effort to add a pot for remote control.Lincoln Square-wave 175/ watercooled Holox TIG torch
Reply:Originally Posted by rgfab242Maybe I misunderstand your post, but set output contactor to remote and amperage to panel/local and your good to go. No need for a pot if you are not running amp control. I run a couple of machines this way. I get really sick of kicking a pedal around all day long.
GMT+8, 2025-12-26 16:10 , Processed in 0.129126 second(s), 18 queries .
