foot pedal extension cable
发表于 2021-8-31 23:29:59 | 显示全部楼层 |阅读模式
I was at my local surplus store and they had 2 miller p/n122973 25' extension cables. I picked one up because it says it will work with various feeders. I am wondering if this cable will work to extend the foot pedal on my miller xmt or power up a 12rc feeder. The cable has 8 of the 14 pins used. http://www.ssccontrols.com/homepage-weldingcables.htm has the 8 pin listed as being used for amp controls and feeders.Thanks, ChrisTOO MANY TOOLS & NO MORE SPACE
Reply:As far as the feeder goes:http://www.millerwelds.com/resources...xtension-Cords"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I powered up the machine and pluged in the foot pedal by itself.  It displays the amperage and when not depressed the voltage screen is blank. When the pedal is depressed, the voltage screen displays 80 something volts no matter how much it is pushed down.  It does exactly the same with the extension attached so I guess it is working properly. I just might have to go back for the second cable.TOO MANY TOOLS & NO MORE SPACE
GMT+8, 2025-12-26 17:52 , Processed in 0.094660 second(s), 18 queries .
