Welding mild steel tube with 308L wire
发表于 2021-8-31 23:29:56 | 显示全部楼层 |阅读模式
I have to do some welding to do. Round rod with a bevel. I don't have any ER70s6 wire in .045. 1/16th is a little too big. Are there any down sides to using 308L .045? It's a little too convex with 1/16th.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Do you have any mig wire you can use instead?(I'm assuming you are tig welding)Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yes I'm tig welding. I think .030 wire, but it may be a little small. I would rather use .045. Would the 308L filler be stronger than mild steel wire? Or downside to using it?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleYes I'm tig welding. I think .030 wire, but it may be a little small. I would rather use .045. Would the 308L filler be stronger than mild steel wire? Or downside to using it?
Reply:Would you use 309L over mild steel wire?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleWould you use 309L over mild steel wire?
Reply:Ok. And 80DS is for chromoly right?I can't find anyone that sells a pound of this. Maybe 2lbs max.Last edited by Gamble; 07-30-2013 at 04:14 PM.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleOk. And 80DS is for chromoly right?I can't find anyone that sells a pound of this. Maybe 2lbs max.
Reply:Originally Posted by shovelon309L is the best ss filler if you had it. The 308L would be weaker and softer than mild steel wire...
Reply:Originally Posted by MikeGyverI'm pretty sure stainless is harder not softer...
Reply:Originally Posted by tig_21It's weird this is brought up because I've heard both. One guy being a machinist for 25 years has said that stainless is softer as well.....I guess its what your definitions of "soft" or "hard" are.....?
Reply:Originally Posted by SquirmyPugDepends on the steel/stainless and what state is in. I have read charts that list +- 50-60 brinell hardness for each steel.
Reply:Originally Posted by MikeGyverFunny, that's why I say its harder. I've heard some alloys like 316 are hell to machine, even when cut properly to minimize work hardening, which is why machinists love 303 free machining stainless.Depends on the alloy and temper, but A36 is always butter.
GMT+8, 2025-12-26 17:55 , Processed in 0.230194 second(s), 18 queries .
