What to do with these
发表于 2021-8-31 23:29:52 | 显示全部楼层 |阅读模式
I came across 7 large steel balls.  They are used for rock crushing in mills.  They are each about the size of a baseball and I have been trying to think of what to do with them for fun.  (they look like in pic attached) So I thought I would see what you guys came up with.  A mace would be fun but I moved away from that.  I am thinking of building a Newtons Cradle  that would be huge for my desk just because it would be so over the top. http://www.officeplayground.com/Newt...inch-P160.aspxAnyone have any good ideas? Attached Images
Reply:I used to haul iron after it was run thru a ball mill. It started off as iron shavings/borings, and ended up like iron baby powder. It was mixed with wood shavings in a field. Then was watered and churned/plowed with a farm tractor, for about a month. The finished product was used to filter natural gas. I used to get those balls all the time. I think I still have a few smaller ones. I never knew they were used for rock. I can't think of any uses for pulverized/powdered rock. And talk about a LOUD process!!!They would be great for going thru a car window after some jackwaggon almost causes you an accident. But that is just in theory!Last edited by Stick-man; 12-16-2011 at 10:58 AM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Have been told that it crushes ore for extracting copper around here and also for limestone to get cement.  Dont know for sure tho.Yeah, betting would make a great bouncing ball if someone gets to close to me on my harley,,, but only a theory.Just looking for something fun to do with them
Reply:You could barter with a blacksmith, and see if he'd take some in trade for turning one into a hammer/tool for you.
Reply:Manly juggling.
Reply:only while i wear flip flops...
Reply:Originally Posted by mattlago...A mace would be fun but I moved away from that.
Reply:put 2 in your pants and brag about having balls of iron.....LOLOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:kegel exercises...you could build a small cannon to fire them, but dont tell the ATF
Reply:Build a cannon and shoot them at barrels full of water to measure velocity.  Can't do much worse than Myth Busters under their closely controlled conditions. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:"Build a cannon and shoot them at barrels full of water. Can't do much worse than Myth Busters under their closely controlled conditions."Thats funny.  If I was using their standards, I could just fire them off in my living room
Reply:make a cannon ball stack?bobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:I have a bunch of those laying somewhere behind the garage, Used to be used in the taconite mills up here but they have all pretty much gone to rod mills. Basically replaced the balls with 20-30' 2-4" diameter steel rods. Rock goes in one end and very fine powder and tailings comes out the other, then its on to mag seperation
Reply:I think you should do an over-sized Newtons Cradle. The sound would be awesome, and the bigger is ALWAYS better mindset applies. But please, please, post video if you do it, I wanna see it done!Good Luck
Reply:Originally Posted by mammaogiI think you should do an over-sized Newtons Cradle. The sound would be awesome, and the bigger is ALWAYS better mindset applies. But please, please, post video if you do it, I wanna see it done!Good Luck
Reply:Bowling......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:the newton's cradle was the first thing that came to mind for me. but the novelty is almost to obvious. you could make an oversized lazy susan for your monitor. drill a couple holes in one and use it as a pen holder. Paint one to look like a baseball and see how long it takes for someone to break their wrist trying to hit the thing.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Rolling ball sculpture to scale."These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Throw them at your ex ......
Reply:Having 7 of them I would definitely be thinking cannon... I have a "well used" one sitting on my desk, people who see it think it's a meteorite.btw, those are usually Manganese steel, keep that in mind if you're going to do anything with them that involves welding.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:make a gorilla fist and use it as a pdwLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Personally I would weld some chain to them and hang them from the rear of my truck.
Reply:Add a lenngth of chainand an ankle coupler and give them to your married buddies as a Christmas gift. As if they need ANOTHER ball & chain Or give them to unmarried buudies who don't already have a ball and chain.
Reply:Start a new trend in piercing?
Reply:Originally Posted by mammaogiThe sound would be awesome, and the bigger is ALWAYS better mindset applies. But please, please, post video if you do it, I wanna see it done!Good LuckToss out the sun roof to deal with tail-gater's...........quite country roads only of course.....200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:weld a chain between them and pad lock them on your receiver hitchtackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Ive got a couple hundred of them. All rusty. I set up a smal mechanism to facet them.  They are really tough to drill. they seem to weld alright but I never tested them for strength  I'm going to build a ball mill to crush gold ore. Around here there is a lot of gold ore, but very little gold. Mac.
Reply:Stick-man,crushed stone makes an excellent base layer for a patio.  Instead of washing away like sand, it turns to clay and gets hard-keeps bricks and flagstone from cracking.As for the OP, how about a hybrid idea.  Weld two balls to piece of chain, then stick THAT in a cannon!
Reply:I would build a harness and carry a couple of them in the front of my pants.
Reply:Id like to tell you that there is no room in my pants,,,, but im Irish...
Reply:Originally Posted by BistineauAdd a lenngth of chainand an ankle coupler and give them to your married buddies as a Christmas gift. As if they need ANOTHER ball & chain Or give them to unmarried buudies who don't already have a ball and chain.
Reply:Send 'em to me!  I've been told I've got no balls!Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by Bazooka_LucaStick-man,crushed stone makes an excellent base layer for a patio.  Instead of washing away like sand, it turns to clay and gets hard-keeps bricks and flagstone from cracking.
Reply:ah, the curse of the Irish.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Um... Fushigi?
GMT+8, 2025-12-26 16:08 , Processed in 0.103454 second(s), 18 queries .
