havent welding in a few years
发表于 2021-8-31 23:29:49 | 显示全部楼层 |阅读模式
Ill set the welder up propely,, I should have the hand motions come back quickly?
Reply:muscle memory is a great thing. If you were decent before, it wont take long to get back too it. I hadn't welded with stick in almost 15 years and once I got used to starting the arch again it was natural.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammermuscle memory is a great thing. If you were decent before, it wont take long to get back too it. I hadn't welded with stick in almost 15 years and once I got used to starting the arch again it was natural.
GMT+8, 2025-12-26 17:55 , Processed in 0.117557 second(s), 18 queries .
