just passed my first bend test in college !!!
发表于 2021-8-31 23:29:49 | 显示全部楼层 |阅读模式
had a bend test to take on 1/4 in bevel plate had to use 6010 for root and 7018 for fill and cap cut 4 coupons out of the steel all passed had one that got a 1/8 in inclusion but instructer said it passed .worked for 3 days for this needless to say im happy  ill post picks later
Reply:Good job brother!  I remember being perdy stoked myself when I passed my first bend test.GarLincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:Bleh... Destructive tests... Ya, always round those edges on coupons.. My buddies and i at shop have bent plain stock pipe coupons with no weld and witnessed cracks and end tear... Tge steel can have manufacturer defects from the initial cast... Good job brotherSal
Reply:Congrats!.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Dang!That was fast. Good Job.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:forgot to say it was in a 3G position dang phone wont connect to wifi so i can upload pictures cant wait to get to my 6G pipe test thank you all im finally doing somthing i love to do and hope to be a pipeliner or boiler maker after college
Reply:That is Cool! Passing something like this right out of the gate (assume this was the first attempt) makes you feel like the hard work is worth it.
Reply:I remember my first bend test...WAS FREAKING THE HELL OUT! then I passed and the rest is all practice. Congrats man. keep up the good work.
Reply:Originally Posted by ESeemannThat is Cool! Passing something like this right out of the gate (assume this was the first attempt) makes you feel like the hard work is worth it.
Reply:Congrats..   Now from here on out, all the other tests will be a piece of cake..
Reply:Cool. There's nothing like that feeling of passing your first bend test. Now work on passing more with no inclusions, flawless! Don't forget to take notes! Always take notes of your settings, whatever will help you improve on your next plate. I always use to take notes of my wire speed, amps/volts, gun angle, travel speed, any motions used. Trust me, taking simple notes will help you so much while your in the learning process.  Good luck!
GMT+8, 2025-12-26 17:52 , Processed in 0.129543 second(s), 18 queries .
