Making a Sa-200 conversion
发表于 2021-8-31 23:29:48 | 显示全部楼层 |阅读模式
I was wondering if there is any way to replace the push button start on an Sa-200 blackface to a Key ignition system? Any help would be appreciated.
Reply:well that was easy. my reason was people have fingers. and fingers like to touch stuff...my start button mainly.
Reply:Just make sure you DON'T wire it up to apply 12VDC (+) to the mag coil or you'll be buying a new one.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeah I will be doing some intense research before attempting anything. Any help or links will be greatly appreciated
GMT+8, 2025-12-26 17:44 , Processed in 0.096403 second(s), 18 queries .
