Lots of Aluminum projects
发表于 2021-8-31 23:29:45 | 显示全部楼层 |阅读模式
Anything from a one off frame to a ramp for a tractor I weld a ton of aluminum a year...Light pole for the city.........  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:That light pole weld is amazing.. That is some hefty stuff?  How many amps did it take?
Reply:Originally Posted by poop24That light pole weld is amazing.. That is some hefty stuff?  How many amps did it take?
Reply:As you may have figured out I built my shop next to my home and I'm semi retired....So most of my money goes for coffee and donuts.....LOL  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I think I've seen that welding table design somewhere before.  Nice welds.  Nice photos.  Thanks.
Reply:Originally Posted by WeldordieI think I've seen that welding table design somewhere before.  Nice welds.  Nice photos.  Thanks.
Reply:Nice work on the lowbed ramps, those things are a PITA to weld lots of ground in nasty stuff to grind off before you can strike an arc.    plus to buy those from Murray is over 2K.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by B_CHow cold is it right now?
Reply:Wow that is terrible.......You guys ever use the kerosene heaters, you have to keep fresh air circulating but the heat is there....Last edited by B_C; 02-22-2011 at 06:36 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CWow that is terrible.......You guys ever use the kerosene heaters, you have to keep fresh air circulating but the heat is there....
Reply:Nice, what did you do for prep on the weld down by the base of that light post? Is it solid?
Reply:I just buzz off the paint with an angle head sander die grind a groove and weld it up...Solid, no it's about 3/8" thick cast......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-26 15:47 , Processed in 0.071510 second(s), 18 queries .
