Welder repair man in Michigan
发表于 2021-8-31 23:29:40 | 显示全部楼层 |阅读模式
Not sure if this is the right place to post this. Anyone near Detroit repair old miller welders? I have a scp200 and a 330 and neither are working properlyMillermatic 210 & 300Miller 330 a/bp w/Miller coolmate 3Lincoln 225 ac/dc buzz box200amp Hobart 16hp portable welderCarbon arc torch, oxy/acy, plasma cutterCNC plasma table
Reply:Steve ( 7A749) is in Michigan I believe. Not sure where he is in relation to Detroit though. He can probably get you taken care of. He's done a fair amount with the old Millers and he does top notch work.Edit: I see Steve beat me to it.Last edited by DSW; 08-07-2013 at 11:20 PM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:When you can get it to weld, it welds great. Seems like the thicker the metal the better it welds. It welds like it has a bad ground. The place I got it from called it the bap bap bap welder because that's what it does. I put a new ground clam on it and replaced the gun and cable and still has the same problem. It's for sale for the right price but ideally I would like to fix itMillermatic 210 & 300Miller 330 a/bp w/Miller coolmate 3Lincoln 225 ac/dc buzz box200amp Hobart 16hp portable welderCarbon arc torch, oxy/acy, plasma cutterCNC plasma table
GMT+8, 2025-12-26 15:48 , Processed in 0.106367 second(s), 18 queries .
