12 ga. Steel Wire Welding with Oxy/Acetylene
发表于 2021-8-31 23:29:40 | 显示全部楼层 |阅读模式
Hello everyone, I've been trying to weld a piece of 12 gauge steel wire together with no success. As you can see in the picture below I need to weld the two ends together. I'm using and oxygen/acetylene torch, and I've made sure I have a neutral flame. Someone suggested I use the same steel wire to weld the two ends together, so I tried but the steel becomes too brittle and breaks. I've also tried using RG45 but I get the same results.Could anyone please tell me what I should do to accomplish this? Any help is greatly appreciated. I've already spend too much time and money trying to do this on my own. Thanks.
Reply:Hi, you should have used the plasma welder I use........check my other posts for details.Ian.
Reply:What kind of wire is it?  Is it coated?What tip size and settings are you using?Use a very small tip on your torch - very small.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:................nice CLEAN sharp edges, one little snippet of silver solder...........just sayin....6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by MinnesotaDaveWhat kind of wire is it?  Is it coated?What tip size and settings are you using?Use a very small tip on your torch - very small.Dave J.
Reply:Control the heat, try fusing.  I used to to repair topiaries.  Found that fuse welds worked well.  Are your sure you have a neutral flame. Should only take 1-2 sec before fusing tempDont know how galvy will effect weld.
GMT+8, 2025-12-26 15:47 , Processed in 0.069496 second(s), 18 queries .
