Stainless
发表于 2021-8-31 23:29:37 | 显示全部楼层 |阅读模式
I started with a big, heavy stainless flange..The holes got a slight chamfer  cut by mistake so I had to weld it up so I had a good fit to weld the tubes in that followed.......    We are talking big tubes here so this got real heavy fast.....Welded on both sides this part is used to run huge wire cables under water I had a hard time loading this in my Pick upLast edited by B_C; 02-24-2011 at 01:38 AM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Welds look fine. Did you consider a purge to avoid the heavy heat tint on the bore of the pipe ? Will this area be exposed to water ? There is some possible chrome loss in these areas, however may not be important.
Reply:I didn't worry about that since it was fairly thick material and there wasn't a pressure issue, just leak tight  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:ummmm. I was talking about the internal bore location. There is a possibility this could be a corrosion site, especially in an aqueous environment. Cheers
Reply:Originally Posted by chrispc66ummmm. I was talking about the internal bore location. There is a possibility this could be a corrosion site, especially in an aqueous environment. Cheers
GMT+8, 2025-12-26 17:28 , Processed in 0.112932 second(s), 18 queries .
